- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
i post this in others vehicles because i dont know of anything you would need resistors for, and my application is a sedan for turn signals(no flasher to change, have to do load resistors)
I have 50w 6ohm resistors i need to mount, 2 in front, 4 in rear. The front are not of concern, they can be mounted such thatthey have air flow or not touching anything painted, plastic, or etc.
Rear two are the problem. to mount a load resistor, I need to get the resistors to clear the trunk lid, mount it to the raised sheet metal portions and somehow insulate it from the carpet on the Lid/cargo in trunk while also not baking it to death......
this pic is generic, but the trunk lid placement for the tail light bar means nothing can sit next to the tail light for clearance and heat.
Or im gonna need to wire it in MUCH earlier in the wiring harness or run wire back to/on the rear fenders, next to where the tail light is also present on the body of the car, which is also needing resistors. (ill post pic of what i have to work with soon, i have to take pics)
I dont have a problem running a wire back, but then im putting 3 resistors on one fender, presumably close to eachother, still needing to insulate from cargo and the trunk carpet. I can imagine thats a little warm of an idea. The other would be on other side of the trunk. There is a trunk pressure/heat/liquid/etc vent that is on passenger side, so it would have periodic exhaust times, just a plastic flap.
so that leads to the overall, overreaching part. Where can I mount these to not affect plastic, rubber, carpet, cargo from burns/fire while also keeping them cool?
I dont know how much heat they would make or what they can safely mount to, but on their own they get very warm after 5 minutes of turn signal operation(they are only heating when flashing, no current when off) in 40 degree ambient, mildly windy, open in the air(literally hanging in the air) to the point i cannot hold them. I did this test to simulate the best possible conditions in ambient air(other than 40 below) with sittting in traffic trying to turn. If it cant pass thgat test, then I assuredly need to work a scenario for 105 degrees, humid, in traffic, in a trunk full of **** lol
