Where do the engine bay decals go?
MisterB
Northwest
AJ
GMC K2500 4X4
My truck had a frame off restoration and repaint, and all the stickers were removed in the process from under the hood.
LMC sells them, so I bought all the correct ones for a 1980. Are there pictures or drawings that show where they are supposed to go?
Sent from my SM-N975U1 using Tapatalk
Keith Seymore
Motor City
Keith Seymore
4.3L
The assembly manual (Product Assembly Manual, or "PAD" sheets) would show where they go.
Or - if you want to be more specific about which ones you bought the guys here can probably tell you.
K
80BrownK10
Greenwood, SC
Nate
I can take a picture tonight under the hood of my 1980 they are all still there I believe.
MisterB
Northwest
AJ
GMC K2500 4X4
That would be awesome. Thanks!
80BrownK10
Greenwood, SC
Nate
The only sticker I have under my hood is this one.
It's not even straight. I can't say for sure but I have no reason to believe that this is not the factory sticker.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
One on the air cleaner , drivers side, that says Keep your GM vehicle all GM (mine is about gone, sadly) and what about the ac stuff ?
Let us know what you need !:waytogo:
80BrownK10
Greenwood, SC
Nate
Yea I didn't think about the AC box. I can take that pic if you like.
And since I don't have and never had a factory air cleaner I never saw the one on the air cleaner.
MisterB
Northwest
AJ
GMC K2500 4X4
I don't have AC, so no need there
MisterB
Northwest
AJ
GMC K2500 4X4
There's a coolant one, something about the routing of the belts and hoses, and maybe one other. Oh, and the "keep your GM sticker" for the air cleaner that I'll leave off seeing as I have a K&N with Edelbrock cover lol
MisterB
Northwest
AJ
GMC K2500 4X4
They did a full frame off and didn't install AC??!!
It really isn't needed in the Northwest. Put the windows down, open the floor vents, and you're golden.
AC is just more fluff, more stuff to break, and more expense
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Nothing I see about coolant, or hose and belt routing. That sounds more for a serpentine set up to me.
Emission sticker:
GM sticker fragment:
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Does your sticker show an air pump ?
Mine does, but I don't have one. I assumed it had been removed, but I read somewhere where the stickers were somewhat generic and it may have never had one.
Since the passenger side exhaust manifold does not have plugs in the middle ports where air tubes would have gone it adds to the no air pump scenario.
MisterB
Northwest
AJ
GMC K2500 4X4
I bought this one, so that's helpful. Thanks
MisterB
Northwest
AJ
GMC K2500 4X4
LMC says these are all for an '80, other than the emission control one, which they say is for 79 but none at all for 80. I went ahead and got it, since my truck was likely built in 79 anyway
Sent from my SM-T720 using Tapatalk
NateP350
