wheel bearing trouble
firebane
Calgary, AB
Curtis
The wheel moving around and the noises have nothing to do with anything behind the spindle, Unless you are getting the noises while in 4wd only?
Wheel moving around is loose bearings generally or bad ball joints. But if had the spindle all apart to do work its best to put it back together properly :shrug:
MadOgre
NA
NA
NA
NA
NA
Yep I agree. But i dont want to confuse him
MannyDantyla
Lawrence, KS
Danny
sbc350/sm365/np205
It's in 2 Hi and I have manual locking hubs that are in the free position. So, no, I guess the spindle needle bearing is not the issue?
I also don't think it sounds like it would be ball joints. It's not a squeeky sound and no noises are made when I shake the vehicle around.
firebane
Calgary, AB
Curtis
Last time fluid in the front diff or transfer case was changed?
MadOgre
NA
NA
NA
NA
NA
Ok so how exactly did you install the wheel bearings?
MadOgre
NA
NA
NA
NA
NA
What I mean is: What exact procedure did you use to install/press the bearings into your hubs ?
firebane
Calgary, AB
Curtis
I loaned a bearing press kit for Oreilly Auto Parts and followed this guys video: https://www.youtube.com/watch?v=KEfaL1TkrZg
Yup while his videos aren't "through" it does get the job done. I would say it honestly sounds like 1) You didn't do the spindle bearing correct 2) You didn't torque down the spindle nuts properly.
I would redo those and if the noise still exists then its something else somewhere.
MannyDantyla
Lawrence, KS
Danny
sbc350/sm365/np205
Yeah, that's what I guess I'll have to do. Dammit!
MadOgre
NA
NA
NA
NA
NA
If you installed them like him you should be fine and yes 150 ft lbs is about all you can realistically get on that lock nut lol
If the wheel bearings are on and torqued correctly that leaves you with, only the spindle nuts on the back side of the spindle being loose. Which I would suspect is not the issue as it sounds like you've done it right. Or the knuckle ball joints, that could possibly allow wheel movement from side to side or up and down.
The noise may be associated with the brakes ?
MannyDantyla
Lawrence, KS
Danny
sbc350/sm365/np205
That makes sense about the ball joints, I see now how that could be the issue.
I took this photo the other day, you can see the ball joints are not in the best of conditions.
MadOgre
NA
NA
NA
NA
NA
Those look like they might give a bit of noise while turning. Those are the drag link ball joints that move when ever you turn the steering wheel.
This is the knuckle ball joint where buddy has his socket
firebane
Calgary, AB
Curtis
Grab all those components underneath there and wiggle them. There should be no play whatsoever and if anything has ANY amount of play it needs replacing.
Put it this way I have no replaced EVERY possible suspension component on the front end of my truck since I had to redo my wheel studs.
MadOgre
NA
NA
NA
NA
NA
There is one on the top and the bottom of the steering knuckle on both sides of the axle. So 4 in total. These are what the wheels actually pivot from.
If there is play in the wheel it can only come from these ball joints
firebane
Calgary, AB
Curtis
Or a bad rag joint.. or bad leaf spring bushings don't ask me how I know :party36:
spartantx117
