Whats the difference in these ?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Might be a dumb question, but I'm eye balling a detroit truetrac for my 79 c10.
It seems to be the only one that'll hold up to much power past 500hp, aside from a spool or a real deal detroit.
Matter of fact, research seems to suggest the truetrac will live up to 900hp. I'm not running a spool or a actual detroit.
Can maybe someone explain the differences here ? I must be missing something.
My truck 12 bolt is a 8.875 ring gear, 30 spline axles.
Eaton 913A315 Detroit Truetrac 30 Spline Differential with 12 Bolt for GM Truck https://www.amazon.com/dp/B001DNBRUU/
Detroit Locker 913A555 Trutrac Differential with 30 Spline for GM 87/8", 12 Bolt Rear End https://www.amazon.com/dp/B003XJ6M8E/
As an Amazon Associate we earn from qualifying purchases.
yevgenievich
Place
Name
Year
Model
Size
There are truck and car 12 bolt axles. They are different
Vbb199
Salisbury NC
Vince
Turbo4whl
Downingtown, PA
Wayne
The Truetracs I put in my 10 bolt GM trucks have two sets of sprial cut spider gears. The Ford F750's we have at work have three sets of sprial cut gear Truetracs from the factory. Large differentials pushed by 6 cylinder Cat engines through a 6 speed Allison 3000 world trans.
The second link picture shows a cut-a-way of what looks like a 4 set of sprial gears. Something in a military truck
yevgenievich
Place
Name
Year
Model
Size
Vbb199
Salisbury NC
Vince
Well thank you kindly Viktor! That's easy enough
yevgenievich
Place
Name
Year
Model
Size
No problem. I have settled with true track as well for one of my vehicles. But it is behind a 200hp 305...
SquareRoot
Put a 14 bolt in it and buy my Detroit locker.
Vbb199
Salisbury NC
Vince
I believe I'll pass on a 14 bolt in the truck, BUT, I still am interested in the Detroit for my s10's 14 bolt.
alwaysbroken
