What offset are you all running?
Mike Kendall
Washington
Im in the process of deciding on wheels/tires for my 1980 C10. Im lowering it 4" front and 6" in the rear. Im leaning towards an 18" wheels. Ive done a bit of research but most wheel discussions do not include offsets. If you are running aftermarket wheels could you please chime in with you wheel specs including offset, width etc as well as tire size.
Thanks
Sent from my SM-N960U using Tapatalk
Wheel offset is just a byproduct of the two most important measurements- width and backspace.
Mike Kendall
Washington
You are correct. Probably going 18x8, 18x10 but not sure on offset and backspacing. Do you have any suggestions?
FireTruck1984
Michigan
1984 and 1984
I'm not sure on what fits. I know that with 15's you generally can't have anything over about 4" backspace, but with a larger diameter rim there is probably more clearance. So if you want to stuff as wide of a wheel as you can up front then you will need to take advantage of having more clearance for backspacing.
But if you just want to bolt up an 18"x8" on the front and call it good, then a common 4" backspace should work fine. Anymore backspace than that, the wheel will be too far inside the wheelwell, imho.
Mike Kendall
Washington
Thanks for your input, much appreciated!
Raider L
Shreveport, LA
William
@FireTruck1984,
Wow. I didn't know that's how a 5 lug was measured. I really didn't know because I never have bought a set of custom rims that were different from whatever was offered off the shelf. All I ever knew was a Chevy rim was different from a Ford or Mopar rim because of the stud pattern, not really anything else beyond that.
I did know about back space but "offset"? By what ya'll are saying I see where it would come into play.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Fire truck,
Great help with the instructions on how to measure for offset. Thank you..
Randy and Easton
adhkjashda
