Marine Corps Moderator
One of my buddies that is a welder suggested these. So I got one for each of my welders and one for my Plasma cutter
nvrenuf
Mobile, Al.
These replace a regular clamp, correct? I’ve seen other similar ground magnets and wondered how well they’d work.
xm20k
Girard, Ohio
Dejure
Eastern Washington
Kelly
C15
I'm a cord guy. That's because I run a "grinder" hours at a time.
Add to the foregoing, I spend the extra hundred, give or take, to have the variable speed versions. I've found having variable speed capability opens all sorts of doors. For example, I use my Makita and Milwaukee as granite routers [with the appropriate diamond router bit] and polishers (I since scored a Flex with the water feed [but which is only one speed - wide open].
Sad Sack
Nebraska
Goober
C15
The right mag ground clamp on a clean bare metal surface works great, been there done that and liked it a lot.
KSSB
Kansas
Ty
Custom Deluxe, Silverado
250 I6, 6.2 Detroit
Picked up the under the hood light a couple months ago, and it's fantastic. My first M12 "tool". So yesterday, I added to my M12 tool stable. I also finally got my M18 top handle saw. Ordered it 3 months ago.
KSSB
Kansas
Ty
250 I6, 6.2 Detroit
Been wanting one of these for a while.
What's the Teamsters book? Is that what union you operate under on the railroad?
Yes it is. I'm BLET (Brotherhood of Locomotive Engineers and Trainman) Local 834, and we are apart of the Teamsters.
legopnuematic
Licensed Junk Dealer
MO
Spencer
A friend down in Georgia had saved the table off of a small Cincinnati milling machine for me that was being scrapped. Kind of a shame as the table appears to be in very nice condition, I would assume so was the rest of the mill.
Anyways, I think will be a nice compliment to the welding table and perhaps even on the Bridgeport as a big angle plate or jig plate. Weighs 220lbs.
KSSB
Kansas
Ty
250 I6, 6.2 Detroit
I've got a Cincinnati horizontal mill that I bought for a couple hundred bucks 6, or 7, years ago. It was in pieces, and came from a college. The mill looks great, but missing several pieces, gibs and what not. I saved it from the scrap yard, but it's probably going to get stripped down and parted out. Maybe it will help someone else keep theirs going. The table is one thing I wanted to utilize in some way. It is a heavy sucker, for sure.
jw23655
