Dejure
Eastern Washington
Kelly
C15
I just bought one of the 179 dollar specials, a "2 ton" (yeah, right), with four wheels. In fact, I have to run to town because I don't want to settle for the supposed grade 8 used to pin the leveler or chain, to finish assembly (a Walmart special, with zero directions, zero washers).
The ram says it's good for ten tons.
The farther back I slide the horizontal part, the more weight it's indicated to hold.
The EIGHT ton ram on a two ton picker makes sense, in a overkill way.
If you need photos or anything, just yell.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Herb Alpert would approve of that name.
I generally call them heel bars.
Because I’m an enabler and like leverage tools, die hooks are another fun type of pry bar:
Moderator
This is what I was referring to. They're various sizes, have a pry bar on one end and a punch on the other. We call them LadyFingers lol
It's a stabby grabby bar.
Dejure
Eastern Washington
Kelly
C15
On those bars, I have many different bars I've acquired over the years. I also ended up with small metal cylinders I inherited via marriage, and that would have got tossed, had I not rescued them.
I duct taped one of the 3/4" by 3" metal dowels to the "straight" end of one of my crowbars for dedicated use to lifting tires in place. It beats trying to lift the monsters that pass for tires these days.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Heel bar is the nomenclature I remember from way back in the 20th century. Ladyfingers is cool too.
Dejure
Eastern Washington
Kelly
C15
I worked a truck stop for years, as a kid (around 60 years ago). Busted down and mounted a few thousand tires. Don't know that I ever knew the name of half of what I used (duck billed hammers and pry bars, etc.).
Hell, we didn't even have a safety cage for airing up the tires. We leaned them against the corner of the roll up door and went out in the street and got them back, if they blew. The concrete at that door edge was pretty chewed.
A couple times, one of the guys would put the tire and rim under the lift and lowered it over a split rim, to keep the ring from launching. Looking back on it, that was iffy, since dropping the lift too low wouldn't let the tire expand to seat on the spit rim, critical to seating beads.
Marine Corps Moderator
Got my plasma cutter. Haven't hooked it up yet, but its here.
legopnuematic
MO
Spencer
Got a 58" Icon (made by Mayhew, made in USA!) pry bar with the extended parking lot sale. Also got the variable pin spanner set.
Moderator
I bought one of those to have on the work truck. I just assumed it was a direct copy of my older Mayhew bar. The newer Mayhew bars have a different handle that is more bulky.
legopnuematic
MO
Spencer
Got a set of collets and a clamp kit for the Bridgeport, and an "educated nut," which is a quick adjust stop for the quill.
jw23655
