77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
As far as steering correction after you do a lift you can do a drop steering arm off the steering gearbox or a raised steering arm. Some say you want the drag link parallel to the ground. That is only an accurate statement when your truck is stock height.
As you raise it you leaf springs start getting an arch to them and are no longer flat, or even reverse arch. ORD states it is best to try at match the angle of the leaf spring pack.
This was after changing from a 3" lift to a 5" lift. The more flexible your suspension is the more bumpsteer you have. With these flexible ORD custom springs it was very hard to drive the truck safely down the road. The drop pitman arm wasn't enough. I put the stock arm back on and used a raised steering arm to get this:
