What is this part?
Loww
Germany
Dominic
GMC K20
...See picture.
Thanks!
77 K20
Montana
K20 5" lift
HT383 fuel injected
Exhaust manifold heat riser vacuum actuator.
Supposed to help heat up the engine faster when its cold.
Loww
Germany
Dominic
GMC K20
Thank you! Can you tell me, where the hose is supposed to connect to?
Craig 85
Nashville, TN
454/TH-400/NP205
Here's the diagram for a 1979 California truck with a 350 (upper right). Go to Figure 30 in the link if you need it larger. It is referred to as the EFE in the diagram. Your rod connects to the heat riser. The nipple connects to the ported vacuum switch. On my '85 the hose goes to the ported vacuum switch located on top of the thermostat housing.
https://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f80cb0d10#
1977chevyc30
