82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
:rolleyes: Gee, thanks Joe, now you have me drooling! lol Nice!! Having visions of a tunnel ram dancing in my head! Yes, a lot of CFM's but not a stock engine! Also have you noticed any difference with your carbs since you installed those deals on your carb nozzles?:smokin:
Nice avatar!!
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Took a little 5 minute ride around the block kinda. The end was the best. Lol
Phone holder was a POS so ill fix that.
Nice!!! Looks like your enjoying that Big Block!!:party52::gm:
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Picked her up from the shop. New rear spring bushings, new sway bar bushings, reman power steering pump - apparently the old one was leaking multiple places, and an alignment . The steering pump was a surprise- the rest is trying to get that good on center feel. Felt better on the way home- we will see tomorrow on the highway.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
But, the cool stuff.
8 months later- no lie - look what showed up!
:D
I'll check the color in the light, but it looks close, and has the sewn in pleats.
Only gripe so far is no buttons, but I bet the upholstery shop can transfer my old ones.
Here's the old one, and the buttons.
Dave M
Banned
Australia
Dave
That’s a lot of cfms for a stock engine;).
Here’s something visual while you’re sipping on some suds.
Nice set-up. This is mine when l gave it a spruce up.
Dave M
Banned
Australia
Dave
Fitted new Monroe Gas rear shock absorbers, what a difference in ride. The old shocks were well and truly shagged. The rebuilt Quadrajet arrived this week
, gonna try to find time to fit that this weekend, need to sort out the electric choke wiring and hook that up also.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Just purchased a richmond 4.10 ring and pinion master install set for my burb.
Ill do the overhaul and regear over the holidays.
Considering the investment in the infamous 600hp 700r4 i have, i wanna squeeze on motor and rear end, less on my trans when towing.
Eventually i'll also add a tru-cool 40k cooler and trans temp gauge.
mrghostwalker
Connecticut
K10/20
I got bored so I pulled the oil pan/sump off of my trucks original blown up motor.
While I was at it, I knocked out the melted piston and found the bore to be untouched, and the rod bearing even looked almost brand new.
One piston, a ring set for it, and a rod bearing ought to fix it right up. I may or may not keep it though since I can't just have another motor laying around.
:eek: DAMN!!!!!
82sbshortbed
Fuckemall!!
SE Texas
Doug
Pulled the Trans brace out of the bed because it kept flying around back there the way I drive. Lol
Anyone need it? Let me know cause I don't. No rust on it. Well, a little surface rust. I'll even sand and paint it for ya if you want.
Vbb199
Salisbury NC
Vince
Wth, im pretty sure thats a 2wd crossmember
82sbshortbed
Fuckemall!!
SE Texas
Doug
You might be right. When I was under the truck it looks like the one that holds the Trans and it's a 2wd.
78C10BigTen
pennsylvannia
C10 BIG TEN
Yea it is, and I am planning on doing that.
I just have to decide if I want to beeline it or not. I like the yellow wheel tubs/inner'bedsides, but berliner would protect it so well. I might just beeline the floor itself and repaint the wheel wells.
Idk of you have one near you but i know line-x does color spray liners.
cmcqueen
