t1xj
USA
t
started taking apart my bbc/sm465 i bought recently, separated motor and trans, got the sccessories off, drained fluids, started cleaning grime off with degreaser and simple green, took oil pan off to clean better.... and found 1 little piece of metal on the magnet. called it a day at that point.
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Bought some hood hinges off Mr Clean!
Just waiting on em to show up now so I don't have to take the hood off to mess with it
Moderator Administrator
It hurts when you drop it on yourself too. You're not a stud until you can't remove and replace your own hood by yourself. Done it several times. It can be done. However, if I had a nice paint job, I don't think I'd risk it by myself.
caliphatman8123
Bakersfield, Ca
Sam
v1500 suburban
tbi 350
Your right it is doable... but these damn square were well built therefore stuff like the hood are pretty heavy for one guy to control by himself... but a couple ratchet straps and a cherry picker go a long way... lol
Sent from my SAMSUNG-SM-N900A using Xparent BlueTapatalk 2
BADAZ chevy guy
Clearfield, UT
Doug
My dad and my friend Chris and I went to the wrecking yard today and got another transmission for my 77 C10. A 4L60 out of a 1990 GMC 3/4 ton van. I'm trying to figure out the code numbers (3BWM434211) I know the "3" is for 1993 and the "M" is for 4L60, but I'm not sure about the "BW" part.
I got it complete with a TV cable, torc converter, Dip stick and tube. But the best part was the sticker on the bell housing. It was a GM re-manufactured transmission.
$145.00
Ouch!! How'd that happen?
silverscottsk10
trafalgar indiana
mike
Taking a cowl off to paint after getting it set
He dropped his end and it caught my arm between the hood and fender caught my elbow
I'd show the picture but some people might get queasy
Wow that sucks
$145.00
The M is just a code for GM transmission, all of them have an M followed my other letters and #'s and some of them even repeat so I usually don't put much into those. You're right, it is a 93 transmission which is rare for the 700r4, so at least you know you have the latest greatest 700r4. As far as the BWM that is just the Service wiring code that tells what kind of vehicle comes in originally, but the wiring harness can be or could have been changed. It also usually tells what size engine it came behind by the wiring code. For example, Could have been a 305 TPI Car, 350 TBI Truck, 4.3 TBI, 350 Carbed, etc etc, I don't have my code book handy to tell you exactly, and it being that late model, my book might not even have the code. But you know what it came out of and probably worked fine in that vehicle. The sticker tells you about all you need to know along with what you pulled it out of. It's a GM Warranty Replacement so it's probably coded to be for any GM TBI Truck from 87-92 and early 93's or the very few models left over that got the NON E transmissions. I'm really not even sure what got the 93 700r4/4L60 without the E. It might have been I6 or V6 Parcel Vans, but to the best of my knowledge, Standard Pickups, S Series Pick Ups, G Series Vans like you got this out of, and the Astro Van series all got the E transmissions in 93. I just know the 93 700r4/4L60 is rare. I've seen one other and that's it. I've seen plenty and have 2 of the 92's which chances are, the same as the 93 since there are no noted changes to a 93.
At any rate, hopefully it works good, and if it doesn't, it should be a good core to build and have all the latest 700r4/4L60 updates in it.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
$145.00
BWM
MD8 TH700R4 4L60
Buick 92-93 8-350 (5.7L), S.W.
Chev Pass. 92-93 8-350 (5.7L), S.W.
Olds 92 8-350 (5.7L)
Yeah, we'd love to see it. It's actually good eye opener and reminder we need to be careful, but Shagster does have a no blood and guts of humans or animals. You can PM those who want to see though. I guess I still don't understand how it happened. :shrug:
Gurn
