gilby959798
CLT NC
GMC K25 Camper Special
Did more of the firewall repair. Gotta go over everything I've done to make sure there's no pin holes then I'll close that up and put the brake booster support back on.
Also did this, coated it with uv resin, it's going on the tool box to match my fender emblems. The resin is unfortunately not level but it's good enough for the tool box.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
well since I got the brake lights figured out-----again, today was spent getting new wire in for the new dome light! bought the socket kit from LMC didn't want to try fishing the wire thru so did a cut and solder job and now ready to go back together with the head liner!!
Finkaire
Finkaire
California
Loren
Silverado c10
No rain today, decided to troubleshoot the wipers. First try they, they come on slow, change speed or turn off they refuse to come back on. Bypassed the module, no change. Cleaned the terminals at the motor and got them to consistently come on, dead slow, any speed is better than the squeegee. I am wondering if the motor has a bad ground. Investigating where the ground is for the wiper motor?
Tennessee
Went and registered my YOM plate and stuck it on. Since its a permanent plate like an antique I shot a little clear on it to help preserve the stickers in the bottom corners as long as possible
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
It goes through one of the mounting bolts, there should be a little tab to the motor body.
waterpirate
delaware
v10
5.7 tbi
Got busy today with a wash and wax. It was 60 here today. Replaced the old battery. Pulled the passenger side rear wheel and hub to back off the drum brake that was dragging. Discovered a leaky wheel cylinder, so that is on the docket for spring.
CoggedBelt75
Oklahoma
Joe
Time for upper & lower ball joint replacement.
Got everything changed out & back together. Tina still tells me to put the tools up. Anything I do, I seem to bring blood somehow.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
My Bride keeps telling me to get a hard hat and wear it in the shop...........looks like you need one, too! Head wounds ALWAYS bleed a lot..........and it seems we have less hair to hide them :rolleyes:
K20SM465
Darryl
Tried to post this the other day but had to shrink them. My wife got me a cowl hood for Christmas.
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Us older farts and our thin skin! I have the same problem I just have to look at a project and I start leaking!!
waterpirate
delaware
v10
5.7 tbi
So I took the old girl in for inspection today. We have state run places you have to take your vehicle. They have long been known to hate anything not new or modified. Going every 2 years it is always a battle royal. Not today????
Did the lights horn thing and wipers and the guy says, your drivers stop light is not working, I will pass you. WTF Never in my life have I got such a break. I move on to emissions. High carbons, fail. The guy says, run it down the highway and heat it up and come back? Oh O.K., will do.
I run 15 miles down the highway and back, passing everything but the troopers, lol. Wait in line some more, pull in. He says did you run it? yes. Did you shut it off? no. He says excellent. He puts the anal probe back in the tail pipe. fail. rev it up, fail. Turn it off, repeat, fail. Supervisor comes over, what is the problem? I think here we go, I am screwed. Supervisor says, do it again and let me see you rev it up, higher, higher. Supervisor yells, I saw it go green you're good to go.
I am here to tell you that I do not believe for 1 minute that needle ever went into the green. It restored my faith in humanity for sure. Maybe it was karma for the 45 years of pain inflicted on me by those people, IDK. Anyways I got my 2 year sticker and hauled a$$ inside to pay.
Maybe I am finally getting cool old guy treatment?
jw23655
