What do I have...Dana 44 or GM 10 Bolt
hoagster
California
K10, 1500
5.3l
Now thats what I'm talkin about!! Any mods to this guy? When I have it apart I am going to replace all I am capable of doing...without a shop or a welder. Great shot!
No mods, Just a new ARB cover and completely refurbished.
Kurnacopia
Tucson, AZ
Scottsdale
I took everyone's advice and cleaned that sucker good this weekend. I found 44-81 stamped on the lower part of the axle. So Dana 44 it is. I've purchase Mile marker hubs, spicer U joints, and timkin bearings and races for a complete rebuilt next weekend. I also ordered a bearing and race driver set. I am chomping on the bit to purchase one of the new cross over steering Knuckles from Offroad design. Let the fun begin!!!
dvdswan
Port Orchard, WA
Dave
10 bolt front axles are more rounded on the diff cover...
Compared to a more angled diff cover of the Dana 44....
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
For what its worth, a dana diff can always be distinguished by its case seperator peg holes cast into each side of the diff cover
Corporate axles dont have such fancy things
Kurnacopia
Tucson, AZ
Scottsdale
Case separator peg holes..... now I'm looking for that as I type.
Vbb199
Salisbury NC
Vince
Kurnacopia
Tucson, AZ
Scottsdale
rpcraft
Robert
LS 6.0 364 CID
I hear the 10 bolt is almost a duplicate of the 44. Anyone know if the parts are interchangeable? I know the guts in the pumpkin aren't......just wondering about all the other external items....
The axles are essentially identical from the knuckles out but the 44 is commonly though to be stronger (especially by the guys who think they don't make things like they used to. It isn't necessarily stronger or weaker but it is more desireable for someone wanting to do a crossover steering setup.
CheemsK1500
K1500
I've only seen one D44 break under normal use and that was on a 2nd gen Dodge Ram truck with a CAD system.
Kurnacopia
Tucson, AZ
Scottsdale
I live in AZ so the country can be very rocky. I want to build a strong axle, yet not overkill. Thinking about chromoly shafts and Yukon u-joints....then I will leave it at that.
CheemsK1500
K1500
That should do it. I've seen stock D30s survive plenty of abuse before snapping, and those are considered "weak" by many. A D44 with upgrades will probably outlast the truck it's under.
My ‘75 GMC K25 has what is called a Dana 44 HD, 4.10 ratio front axle, but I’m not sure what makes it an HD. It may just be whatever is changed at the hub area to allow for the 8 lug wheels.
texdave
