What could this noise be?
thecantaloupeman
US
Dawson
C20 Silverado Camper Special
So I noticed this noise after getting my new tires. It was not there when I test drove the truck originally, but that could just be because it's an on and off issue. Sometimes it just completely dissapears and other days it is there again. It almost sounds like it is inside the cab but I doubt it. It definitely sounds wheel speed related. I have no idea what this could be. Here is the video.
https://photos.app.goo.gl/9RcP8XSvpALZWPH3A
Sent from my SM-G950U using Tapatalk
1985c20
Torrington, CT
Chuck
Is it only when you’re stepping on the brakes? If it’s only after new tires check to see if they put stick on weights inside the rim theatre hitting the calipers or drums. Also check lug nut torques.
climb-101
montana
seth
c2 crew cab
6.0 LS
x2 on the lug nuts. wouldn’t be the first one i have seen that a tire shop forgot to TQ them and the rim was moving on the studs
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Sounds like the rim rubbing the caliper. Just barley touching it. Playing with the brakes shifts the caliper around enough to modulate the sound.
thecantaloupeman
US
Dawson
Well I had my local shop check the brakes and I assume that requires them to remove the wheels. Unless they didn't then that could be my issue.
thecantaloupeman
US
Dawson
It isn't only when stepping on brakes. How do I check if they put stick on weights?
thecantaloupeman
US
Dawson
Check your shocks.
The shop did tell me the shocks could use a replacement, but why do you think that be causing the noise?
thecantaloupeman
US
Dawson
It doesn't seem to be affected by when I press the brakes, but could I just need to grease my wheel bearings?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
If your bearings get the point of making noise... you will be greasing your NEW bearings. Get your hands dirty it's fun!
It sounds like something rubbing on the front rotor(s). Maybe a driveline noise but not likely. Weights, backwards pads, even new pads on ******, worn out rotors that didn’t bed in like they were supposed to... I’ve never heard a wheel bearing that sounded like that. I don’t think that’s it either, but it’s simple to check, replace and repack if needed. Have you tried jacking the front end and spinning the wheels or the rear and putting it in gear?
thecantaloupeman
US
Dawson
I haven't yet, but I'll be sure to do that. I just need to make sure my jack stands are safe first. I have harbor freight pittsburgh 6 ton jacks stands that seem to fall down. I think they are defective because the display model in the store didn't do the same thing.
Dave 84
Arizona, glendale
Dave
How fast were you going does the noise slow down as the truck does? Also when its happening turn the truck off and see if it goes away.
sallyjeank10
