What’s #15 mean?
Italianwagon
Washington
Steve
V20 Suburban
Hey there redoing the brakes on my burban.
the manual says the following: on #15
what does that mean to clinch the upper ears. Here’s the new setup
Auburn, Washington
Means bend the tabs on the brake pad that hook over the caliper tight to the caliper so there’s no slop in the brake pad. Keeps brakes quieter.
Been a minute, or 30 years, since I put brake pads like that on but the principle is the same as newer ones that have spring clips holding them from rattling around.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Has to have been printed in the Haynes series of shop manuals, they talk funny and use words that very few people understand or know the meaning of .........
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Aren't those wear indicators supposed to be facing the other way? Or have I been doing it wrong?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I have never seen left and right disc pads.
The wear indicator is always on the same end of both outboard pads in every set I have seen.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
What I meant is if you put that pad on the other caliper it would be facing into the rotation of the rotor.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
yep, because both outboard pads are the same.
If you switched the pads to the other side, you would end up with the exact same thing.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
:confused:
If you take that pad, and put it on the outboard side of the other caliper the clip will face down instead of up. So when the truck is rolling forward it would be the first thing the rotor contacts (when the pads wear out) instead of the last.
Auburn, Washington
:confused:
But it doesn’t matter which “end “ of the pad it’s on.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Im more concerned about whether it's being pushed or pulled and how it makes noise to indicate that the pads are worn out.
Yep.
Most every set of pads I've ever installed on anything had the wear sensors attached to different ends of the pad. So when installed, the sensor can be on the leading end of both sides.
Italianwagon
Washington
Steve
V20 Suburban
Shoot did I mess that up? Should I flip the brake pads?? Or does it not really matter.
thanks for the help
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
thanks for the help
That seems to be the mystery of the ages here, doesn't it?
El Greengo
