Went from 7/16 to 9/16 wheel studs
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Ok, so I swapped out my front wheel studs from 7/16 to 9/16 on my truck. The rear however is a little trickier, the holes on the drum are too small. My question is, can I drill them out larger with no safety issues, or is there another drum I have to use?
Gmule
Conifer Colorado
Greg
K10 Fleetside long bed
You can drill them out. The drum is held on by the torque of the lug nuts.
You got a part number for those front studs?
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I don't have the part #, what I did, was i went to auto parts shop, the clerk matched up the bolts that were identical to the base (the part of the bolt that is pressed on to the rotor) of my original studs. The only difference was the 9/16 threaded part. Ill call or stop by tomorrow and see if I can get a part # for you.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
If you still have your receipt, the number may be on there.
kains77
