Well The Blazer Broke Down..
87BlazerBeast
Pascagoula MS
Dusty
K5 Blazer
Hmm.. it looks like it is getting wayy too much fuel. So we unplugged an injector and it runs better. Not good,but it does clear out a little
Fuel regulator acting up maybe?
Is it possible there is a piece of junk in the injector tip not allowing it to close off??? Have you looked down the throat of throttle body to see if you're getting dribble or spray?
towman
harrisburg pa
jay
v10
ok was thinking about this, the best thing is to put on a scanner, but there is the coolant switch for the computer that is right beside the thermostat, if they go bad they can read all sorts of crazy temps wich will make the computer on the truck dump fuel like mad thinking the truck is cold, not all the time but sometimes if you unplug it it will allow it to run ok, they cost around 18 dollars for a new one, i have seen them on the scanner reading like minus 30 wich can crate major headaches, have also seen them make and engine run at crazy high speeds,been off work for 6 weeks now due to this stupid rotator cuff so trying to keep my mind sharp.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I had a car one time that had a coolant temp sensor go bad. The result was that the car would think it was randomly running hot & shut off when I stopped. I'd have to hold my foot on the gas to get the thing running again, and it would run rich as hell till it decided it wasn't running hot. Maybe it's possible your coolant switch is doing the same?? Just a thought.......:think:
Can't hurt to check that sensor out, has to be an ohms test that can be done I would imagine. That would be the one on the intake manifold next to the Thermostat housing, not the one on the head.
towman
harrisburg pa
jay
v10
yes there is a ohms test but all my info is at work, the more i think about i am willing to bet that is the problem
87BlazerBeast
Pascagoula MS
Dusty
K5 Blazer
well after replacing all those sensors (including temp sensor) it was just the egr valve. It was stuck. After a little tapping and finessing,and some wd40,we put it back on and it ran better than it ever has! Unfortunately when i took it down the road it stuck again and i had to tap on it to make the truck run to get back home. Oh well,getting a egr block off plate tomorrow.
somewhat of a common issue. Suprised none of thought of that. Probably one of those to easy things, so it couldn't be that.
You did clean the EGR valve well??? Including the pintle? They do clean up and will work just fine. When the vacuum bellow starts getting stuck on the outer walls of the diaphram from rust or something like that, then you can give up on the EGR valve. But in most cases, you can clean the pintle and they be good as new for another few years till the next time its carboned up and needs a cleaning.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Now to get my Blazer back up and running.
Wassup wit it now MBP??? I thought after the cooling issue was fixed it was good to go.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Lol nothing to problematic
Fuel line keeps getting pinched off and it'll die on me while Im driving around
Waiting for some fittings to come in lol
87BlazerBeast
Pascagoula MS
Dusty
K5 Blazer
I'd rather just completely get rid of that damn egr
Yeah, if its in your way of something and you don't require emissions testing, go for it.
Dons79C10
