Wanted: 88 Silverado Cruise/Wiper/Turn Signal Lever
trukman1
Gary
K5 Blazer
5.7 L (350)
I need an original lever for a 1988 K5 Silverado. One with the cruise/wiper/turn signal, all black.
I purchased the K5 sight unseen (stupid) from Idaho. The original lever was broken but bent severly before it broke.
I purchased a cheap aftermarker lever which snapped when my son bumped it while installing my hand controls (can't use my legs.) Then I purchased an AC Delco thinking it would be better. Didn't have my hand controls adjusted quite right and when I pushed on the brakes "SNAP!"
My son is going to readjust the hand controls but I'd like to find a lever that is factory original as I'm convinced it will be better quality than any aftermarket lever.
I think any K5 or C/K Silverado would all be the same. Might be hard finding a column someone will part out but worth a try.
Any help with this is greatly appreciated.
Thanks, trukman1
trukman1
Gary
K5 Blazer
5.7 L (350)
May be open to purchase of entire column depending on cost.
ajd89
Central Michigan
andrew
I might have a switch let me look tonight.
trukman1
Gary
K5 Blazer
5.7 L (350)
ajdemello, That would be greatly appreciated. Thanks, trukman1
ajd89
Central Michigan
andrew
Ok so only one of my columns has a all black switch. But the wire has been run outside the case around the column which I would say means it has been replaced at some point. So its probably an aftermarket one.
trukman1
Gary
K5 Blazer
5.7 L (350)
ajdemello, Thanks for checking that for me. It doesn't look exactly like the original I had. I do appreciate you trying to help me with this. Thanks again!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I have a column I could let go of.
Steering wheel I might keep, but other than that, whole column could be arranged to go.
PM me if interested
Sent from my SM-G965U using Tapatalk
trukman1
Gary
K5 Blazer
5.7 L (350)
Vbb199, PM sent.
Dennis Blom
