Vortec vs Swirl Port spark Plug Location
Ronno6
South Mississippi
Ron
Having read that the spark plugs on Vortec heads are offset towards the exhaust ports causing problems with some headers, I looked at the 193 heads on currently on the engine.
The plugs are likewise offset towards the exhaust ports.
I loosely test fit the headers to see if three was going to be a problem (as the Hedman tech stated) but really see no clearance issues.
Is the spark plug placement on a Vortec head any different from that of the 193 swirl port head??
4WDKC
Southern Florida
Kacy
I didnt compare them but when I did the swap with manifolds I had to buy a manifold spreader tool to get them installed.
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
Ronno6
South Mississippi
Ron
Manifold spreader to install the manifolds...or spark plugs?
4WDKC
Southern Florida
Kacy
exhaust manifolds, I mentioned this so if you run into the same issue you already have your answer.
VFL1982
