Vent window locking latches
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
I'm working on the vent windows of my '83 GMC, trying to get the slack out of the latch.. I removed the latch, cleaned up the "drum", torx screw, and lubed the pivot points of the window.. The screw had worked itself out a turn or 2, but when I put everything back together, some slack remained.. I'm thinking maybe a part is missing or worn to the point it fell out..
The chrome "button" on the outside has a rubber gasket between it and the glass. Looking at the pictures, can someone tell me if something fits between the spring washer and the glass?? Sorry for the blurry pics..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Hope this helps some what it’s all the bits to make it happen looked like plastic on both sides of the glass
https://www.summitracing.com/parts/...CjvHN9P19rOd4JldXSQvjwz3aQGpzCoxoCN3cQAvD_BwE
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Thanks Honky, I didn't think to check with Summit.. That looks to be a "universal" kit as there are way more parts than would fit in one latch.. I have one black rubber/plastic gasket.. Probably need one of the other two plus maybe the white plastic spacer.. I don't see where the second spring would fit.. Their Arlington store is about 100 miles from me.. I'll give them a call..
Affende
ColoRADo
Affende
83 and 84
C1500 and K3500 3+3
250 and 454
mine (83 and 84)have a gasket between the spring washer and the glass. I honestly cant tell if it is a plastic washer or a rubber washer that has hardened over time.
I would assume it is a hard plastic washer that acts as a wear plate so the spring washer doesnt damage the glass over time.
Hard
