Used Replacement Cluster
vicnation
NC
Tristan
I need to replace some components of my gauge cluster in my 1976 K10. I found a complete cluster for a 1977. It has a clock and my original does not. Is there wiring in the dash to account for the clock or is it directly wired by the printed circuit?
The gauges for both sets are not in the best shape. If I were to put overlays on them, would I need to remove the needles? If so, what is the best way to do it?
I also have access to a cluster for a 1979. Are there any differences with regard to connections or front bezel?
Thanks...
Green79Scottsdale
G.R. - MI
Bob
Pretty sure the clock is wired by itself, completely separate from the cluster.
Needles stay on for overlays. I have never done them, but it is discussed in this thread... http://www.gmsquarebody.com/forum/showthread.php?t=16444
76 and 77 trucks are set up for mechanical oil pressure gauges. That 79 cluster uses an electric oil pressure gauge. So all the other gauges from the 79 should swap over into either the 76 or 77 cluster you have, just not the oil pressure. The printed circuit is different between 76/77 and 79.
Front bezel should be the same all around no matter the year.
Hope this helps.
vicnation
NC
Tristan
Thank you! That is very helpful, and now I have a direction.
robracing85
