Turn Signal Switch Repair
87ChevyR10
Kansas
NA
NA
NA
So, I bought a new switch to replace the old. Basically, the old one is split where the silver philips head screw goes on the far left near the lever. I was thinking that instead of pulling the column apart, I'd simply super glue the split so it stays together. Currently, I can get my right side signals to come on if I hold the lever up; however, the left side does not work. That split allows enough play to prevent the lever from working the switch correctly.
So, any suggestions on what glue to use?
Thanks!
87ChevyR10
Kansas
NA
NA
NA
Well, after trying to epoxy the break together, it still failed. So, I ended up replacing the switch. Wasn't too bad. I couldn't get the wire protector sleeve back into the column. But nonetheless, it's fixed.
stonchvy
