77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
Normally I have time to poke around and fix things myself- but the wife's car is not working and waiting on parts to show up. So both of us are using my old truck right now... plus I'm working 12.5 hours shifts. I don't have "spare" time and hope someone can quickly narrow this down.
Neither left nor right turn signal works IF the brakes are being used. When signaling right/left with brakes on the front turn signals light up (on constant), the green turn indicator in the dash is on constant. The rear brake light does a quick flicker but is still on solid. (at normal "brake" brightness).
Other info:
-Turn signals work fine with no brakes on.
-Turn signals work fine with headlights on.
-Hazards work fine with no brakes on.
-Hazards with brakes? All front turn signals are on constant and both green turn indicators are on constantly in the dash. (but thought this was normal)
-I've owned the truck 10+ years and they worked until 2am this morning. It is raining/snowing/sleeting.
-I haven't changed any bulbs recently. All bulbs can light up.
-I have trailer wiring. I bought wiring that plugs into the connector behind the rear bumper (9 years ago). I sealed the connectors in black RTV to keep the weather out. Connector still looks great and looks to be sealed.
-I know all grounds on the engine/firewall/frame/radiator support are clean, ground down to bare metal, star washers used, then sealed on top with RTV/liquid electrical tape. Additional massive ground wire from the battery directly to the frame.
My guesses right now would be to replace the flasher unit. It is 7 years old. Next take apart the rear taillights and look at the sockets. Unsure where the ground is for the sockets.
Then maybe the turn signal switch in the column? Don't own a steering wheel puller and hate messing around in the column.
Is my thinking wrong here?
Other info:
