turbo 400
howlinghuskoe
wisconsin
k25
So the turbo 400 that is in my 78 has the cast aluminum 6 bolt inspection cover. My new transmission I have only has the two maybe 4 1/4 inch bolts. The date code on the transmission says it's out of a 69. It has a 203 transfer case bolted to it. Is there anyway vi can use the aluminum inspection cover or am I stuck with ordering a stamped steel one
MadOgre
NA
NA
NA
NA
NA
You could have all the internals swapped to the K case. I think your out of luck trying to retro fit the covers. I believe if you examine the thickness of the transmission case flanges where the covers bolt to, that they are different thicknesses. If they are the same thickness then you could drill and tap new holes, however I do not know if that's a good idea as you will now have weakened the flange with all the extra holes in it. Its maybe not such a big deal if you are only mounting the cover, in which case it doesn't really matter if you were to use the stamped steel one. The cast cover is used to attach the torque bars from the engine mounts to eliminate torque flexing of the case and ultimately the transfer case. If you are wanting to use the cast cover to be able to use the torque bars I would suggest having your K case rebuilt or the internals swapped.
howlinghuskoe
wisconsin
k25
How big of a deal would it be by not running the cast cover and torque bars? It's just a plow truck it will never be on the road other than to drive it home. It won't be doing any off roading I'm just trying to get the truck up and running to get through winter
MadOgre
NA
NA
NA
NA
NA
If you make sure that the transfer case to bell housing torque bar is installed you should be ok.
But be aware that heavy throttle in 4x4 with the drive line under tension is exactly why those engine to transfer case bars were put there.
howlinghuskoe
wisconsin
k25
The transfer case bars are there and I plan on running them I'm just a little confused as to why the four wheel drive case doesn't have the k case
MadOgre
NA
NA
NA
NA
NA
The 4wd case is the K case
howlinghuskoe
wisconsin
k25
Wouldn't the k case have the holes for the cast cover? This one has the holes for a stamped cover
MadOgre
NA
NA
NA
NA
NA
69 I don't think they ran the bars
howlinghuskoe
wisconsin
k25
That would make sense but 69 didn't have 203 transfer case either did it
MadOgre
NA
NA
NA
NA
NA
Im not sure when they started with the bars.
I had a 6.2 with a th400 and no bars to the transmission just the one to the transfer case. I never broke anything. Mine was originally a 700r4 and who ever swapped in the th400 never installed the bars cause they are slightly different from th400 to 700r4
MadOgre
NA
NA
NA
NA
NA
73-77 for a th400 model so if its on a 69 case then someone did a swap job. th400/np205,203 were popular jeep mods
howlinghuskoe
wisconsin
k25
So someone probably swapped internals or cut the output then?
MadOgre
NA
NA
NA
NA
NA
could be any possibility. Could be a stock th400 with a stock 203
630erik1
