- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I've thought about swapping out my TH350 in favor of the 700R4 because with the TH350 my RPMs are so high at highway speeds with only having the 3 speeds. At 70 mph I'm up in the 3000 RPM range and I'd rather been down around 2200 or 2300. I know that the swap is not just a straight swap as I'd have to fab a new mounting bracket and a shorter drive shaft but from I'm reading from you it'd take a lot more to give it the strength I'd want? I had not heard this before. I'd heard some bad things about the 4L60E but not too much about the 700R4's.
The 700r4 is junkier than the 4L60-E. The E has problems with solenoids and electrical computer issues, but can you really blame that on the trans? Not really. But the 700r4 was such a POS, every single year, improvements were made. Then about the time its becoming an OK trans, now we switch it up with a new set of problems going to -E models. But as far as the hard parts in a 4L60-E they have the better technology design changes in the strength area. Lucky for us, most of the 4L60-E parts are backwards compatible to many of the 700r4s, so you can update the 700r4 with the newer stuff in most cases, but not all. Where you want as far as a 700r4 build, is with an 88-92 700r4 case. (93 went to 4L60-E). So avoid the 82-86 700r4's when possible. The 87 is an OK unit too, but with the changes from 87-88, the 88-92 is preffered. Now many 4L60-E parts are NOT interchangeable in the 82-86 700r4. Just best to find a 88-92 and be on the safer side.
