Turbo 350 dip stick leak
spenser21
a
a
so iv been reading around here and online with other forums and I think I narrowed my problem down. I have a turbo 350 and ive started to notice a small puddle of tranny fluid under her. i changed the pan gasket and filter but I now believe its coming out of the dip stick tube. I have read that the o ring in there goes bad over time and lets fluid by. not so bad right. well the o ring didn't fix the problem so I read a little plumbers tape above the o ring should do it. well definitely slowed it down but still getting by. do I just buy a newer style tube with the better seal?
i did check the vent tube and there is nothing blocking that passage that i can see. any other cause possibly?
74 Shortbed
The grommet works way better than the o-ring, just have to get the matching tube.
spenser21
a
a
that's what ive been coming across... but i would have to get the new tube as well correct?
74 Shortbed
Yes, because the bottom part is skinnier than the one with the o-ring.
spenser21
a
a
awesome. i think im going to give that a try
spenser21
a
a
just if anyone was following and had the same problem, the new tube and grommet style plug fixed my problem! no leaks now!
74 Shortbed
Figured that would do the trick, glad to hear you got it fixed..
Camar068
10 yrs Air Force
Thanks for the update, some people don't update.
spenser21
a
a
just wanted to follow with another update.... been a good 3 weeks or so with everyday driving and still no leaks! definitely worth the investment!!!
74 Shortbed
Shouldn't have problems with it anymore..
guillermoariast
