trouble codes
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
im looking for trouble codes that you read by putting a paper clip in the connector and having the check engine lite blink the codes. it a 87 r10. thanks
Check your PM.
Anybody needs this I have it in PDF, shoot me your email. If I can find the time I'll type it out here unless somebody else beats me to it.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
woops.
Jims86
Patterson,Ca
5.7 TBI
Trouble Code
SYSTEM
Indicating
12 Diagnostic Checking for operation of CEL bulb
13 Oxygen Sensor Circuit No signal to computer
14 Coolant Sensor Circuit Excessive HIGH temperature indicated
15 Coolant Sensor Circuit Excessive Low temperature indicated
16 VSS - Vehicle Speed Sensor Signal Loss
21 TPS - Throttle Position Switch High Signal Voltage
22 TPS Low Signal Voltage
24 VSS Set when in motion only - disregard if set in park
32 EGR EGR system failure
33 MAP - manifold absolute pressure sensor MAP sensor voltage high
34 MAP MAP sensor voltage low
35 IAC - Idle Air Control Motor Idle speed above/below desired idle speed
36 Idle Speed Control Actuator Open or Short Circuit
42 Ignition Control open/short/component failure
43 ESC - electronic spark control ESC module not receiving knock sensor signal
44 Lean Exhaust Low oxygen sensor voltage
45 Rich Exhaust High oxygen sensor voltage
51 PROM (Memcal) Faulty computer chip
53 System voltage high Carging System is over 17.1 volts
54 Fuel pump relay Low voltage / short
55 ECM Computer (ECM) failure
:waytogo:
Bump
