Transmission swap questions
86c10kid
McVeytown Pennsylvania
Clay
400 sbc
Hi, so I’ve got a few questions about transmissions and stuff :) My 700r4 gave out recently and im trying to decide what to do. My neighbor has a 700r4, th350, and th400 that he would sell to me. I would like to go with the 350 or maybe the 400 unless y’all think I should stay with the 700r4. Let me know your thoughts/opinions. Or send a link to another post if this is already talked about. Thanks in advance
There is more than one version of all of those transmissions. What year is his 700r4? What tailshaft length on the TH350 and TH400? Biggest killer of 700r4s is misadjusted TV cable.Were you messing with the cable or did a carb swap?
xm20k
Girard, Ohio
Tail shaft lengths require different driveshaft lengths, crossmember may sit in different position, connectors, linkage, lots of things could be an issue. Need more info.
ali_c20
Austria
Alexander
C20, K5
Rickf
Grafton NH
1974, 1954 & a 1937
Depending on the budget, I would go with a TH400 + a GV overdrive. It's probably the most expensive option, but it would be bullet proof.
86c10kid
Clay
400 sbc
Yes I was kinda messing with it and realize I probably burnt up the transmission. It had the stock 1986 700R4. The one my neighbor has is 1984. The th350 is 1970ish, the 400 is 1979
Not enough info there. You need to know tail shaft lengths on the th350 and 400. At least find out what the THs were out of. The 1984 700r4 is not a very desirable 700r4 unless it's cheap and guaranteed to work. Other wise look for 1987 or newer
xm20k
Girard, Ohio
My bet will be the TH350 will be a 6-inch tail from a car and not the 9" from a truck.
If it were me, I'd go 400 but I could care less about overdrive and changing the drive shaft yoke would be the excuse to change the U joints. Also more likely to be the 4" tail which would work with the yoke swap and shifting the crossmember back and not require messing with the drive shaft length.
Even if the 350 was a 9" that puts you 5/8" over the stock trans which could leave 1/8 of travel a bottoming out issue and lead to a broken tail housing.
jgloria223
Sanger, Ca
Jesse
C15
Lots of great info from all the other guys. Honestly you need to add the question of how your going to drive the truck. Highway driving where the OD would be beneficial or short distance driving where the higher RPM's aren't an issue. You could also always change the rear end gearing to lower those RPM's at highway speeds if you go with a non-OD transmission. This definitely should be part of the equation. Good luck.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
It was the stock transmission and it lasted all these years why change?
I would build the transmission you have, maybe throw a mild TransGo shift Kit and corvette servo in while it's apart...
If the neighbor is selling the 700 for cheap it probably has whatever parts you need.
fishermanjeff
