cha4tterbox
- Aug 10, 2025
- Mount Pleasant, Tx
- Josh
- Sierra C1500
Last weekend, I changed my first transmission pan gasket on my Turbo 350. When I was putting it back together, the pan moved and the gasket isn't even along the edge. It started to drip. So I am redoing it again. This time, I will put the bolts into the bolt holes to keep the gasket from shifting. My question is do I need to torque the bolts to 12 ft lbs after I get them snugged or after I get them snugged, am I supposed to just give them a half of a turn with a regular ratchet and socket? I did my transmission gasket once ,my second time I really wanted to be successful. Thank you all, I hope every single one of y'all have a blessed day.
