- Feb 28, 2025
- Rosemark TN
- Jeff
- C10 swb
- 4.3L
Truck made it 40 years without a transmission service that I know of. And after sitting/being lowered, now has no fluid showing on the stick.
I know, truck abuse, we inherited it when my 92 year old father in law died in 2018. Was mothballed to backup status with a permanent plate.
Plan to pull the engine and the transmission for freshening up. This is a factory installed Th400 behind a gutless wonder carbureted (factory) 4.3L V6. Our local transmission shops quite frankly suck.
Only want to do this once, so…
1. Which components kit for the “guts”?
2. What seals and pan gasket?
3. Will a standard duty finned cast aluminum pan be alright in a truck, or just buy the +2 or +3 quart to stick with a truck sized pan? This is a 6/8 static dropped, never tows but has a heavy period correct topper toy.
I’ve rebuilt 1 C6 and 1 727 previously. Added cast deep pans to those as well, they seemed to seal up better than the stamped, can’t be as grossly overtightened/warped. Thanks.
