transmission help
J-Rod1984
Rock Island, TN.
Jared
C-15
Just bought a 1984 C-15 with a true 350, holley dominator intake, and edelbrock 4-barrel. Not sure what tranny I have but it seems like it shifts too early. Furthermore, when I stomp the pedal it won't downshift. It just accelerates from top gear. This doesn't seem right to me. Any advice?
SlickGTP
Houston, TX
@HotRodPC is usually the go to guy for transmission help, but we still need more information, such as which transmission you actually have.
For help identifying which transmission you have I'd compare the image with your pan.
MadOgre
NA
NA
NA
NA
NA
what is a true 350 ?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
................. Now I'm confused.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I had a problem with mine shifting way too early. It basically went from 1st into 3rd before hitting 15 mph. I have a TH400 and replaced the modulator with a red stripe model from the parts store, and it made it shift a whole lot better. It's located on the passenger side and is easy to change out. I don't know much about automatics, but I do know about the modulator on the TH400...:)
marks86
Latham, NY
Mark
12v Cummins
I am with you 100% same Exact thing I went through, 12dollar part and it was adjustable also
Im pretty sure th350 have the same thing
flynhigh88
