Transmission fluid type 1980 GMC K2500 4X4
MisterB
Northwest
AJ
GMC K2500 4X4
I just need to make sure I get the right transmission fluid for a drain and fill.
Thanks!
Sent from my SM-N975U1 using Tapatalk
Dexron III is spec. Any off brand equivalent or Dexron VI equivalent will do the trick. I just get the stuff from Walmart.
MisterB
Northwest
AJ
GMC K2500 4X4
Cool. I went with some Valvoline Max Life that meets those specs
I mean, the ORIGINAL spec was probably DEXRON I or DEXRON II, but of course you can't buy those anymore (the whole its wrong to buy products with whales in them) but all DEXRON is backwards compatible. Same with ford MERCON
MisterB
Northwest
AJ
GMC K2500 4X4
I just drained and filled the transmission. Put in a new filter and gasket. Old fluid looked nice and pink/red, but the truck likes this new fluid more. Shifts much smoother now.
Wilikers
