TRANS COOLING Question
87Hi-v15HND
chesapeak, va
Daniel
v1500
Just put a Reman. 700r4 in my truck and noticed the cooling lines do NOT run through the radiator. There is an auxiliary cooler mounted along the frame On the passenger side under the bed of the truck. I don’t think that is efficient enough to cool the tranny. So I bought a new cooler that mounts in front of the radiator and a friend of mine told me that still is not enough and that it needs to run through the radiator too! So question is does the lines have to run through the radiator even with the radiator style auxiliary cooler?
To me it’s the same concept. Air runs through the radiator and cools the fluids... some knowledge please?!
87Hi-v15HND
chesapeak, va
Daniel
v1500
This is what is mounted on my frame
And this is what I bought to replace it.
vkh
Western Montana
Var
C2500
Running your trans lines through the rad and an auxiliary cooler is generally the way to go. It's not just about the cooling, it also helps warm it on startups, especially in the winter. Running your trans too cold is bad too.
4WDKC
Southern Florida
Kacy
^ this and the cooler you bought isnt very effective, the best style look like a small radiator like this
cragar62
