Tranny Swap, need info on engine part?
effnay
wyandotte, MI
brad
C10 2wd
hello there all, first post here. been a lurker for many moons and have benefitted greatly from this site and i really appreciate the info i have gained on here. fixed many things by scanning over listing after listing. anyway...
im in the process of removing the transmission out of my c10. i know i do have the 350c in the truck and will be swapping / rebuilding a seperate th350 i have, NON-LOCKUP. i guess my main question is what are these parts that were bolted to the block behind the distributor? im wanting to clean up wiring and clear out anything that really has no use in my truck anymore that does not serve a purpose.
little side note. i have a 1984 C10 longbed that originally came with a inline 6 and not sure what trans. the friend i bought it from awhile back told me the engine and trans were swapped for a 86 model year i believe. 350 /350c combo. not 100% sure, but that was 12+ year ago. man....time flies
im kinda assuming that the smaller one is the oil pressure sensor?, but the other "big" one, heh, is new to me. any thoughts on these parts? took a extra pic removed from motor to maybe help ID.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
yevgenievich
Place
Name
Year
Model
Size
Oil pressure switch and sensor
effnay
wyandotte, MI
brad
C10 2wd
well school me if you would please. is there a difference in the sensor vs switch?
RoryH19
Rory
R10 Silverado SWB
The big one provides the pressure reading on your gauge. The little one triggers the e-choke for the carb when cold.
tinny
