Train wreck
yevgenievich
Place
Name
Year
Model
Size
Not even close to a square, but fits other. Train wreck joined the fleet. Just about everything that could be wrong is wrong with it.
It looks much worse in reality.
yevgenievich
Place
Name
Year
Model
Size
Unfortunately repair list is rather large.
Just starting with rear suspension. Good mechanical condition according to the seller...
yevgenievich
Place
Name
Year
Model
Size
Are those headlamps stock or did someone swap e-codes in? Looks good.
Have not fully verified, but they are likely cheap e-codes. Real correct e-codes go for $2.5k+. The only currently one set I found asking $3.5k.
It is facelifted to 94 front. Actually a 92 model
yevgenievich
Place
Name
Year
Model
Size
Took wheel spacer off on one side for test look. 25mm spacers. picture with spacer removed and wheel located close to desired ride height. Tire is bad as well on that side
yevgenievich
Place
Name
Year
Model
Size
Spacers lost 10mm. Diff might be toast, not confident that noise is the bad axle shaft.
Johns C10 Hubcap
