Tire size?
Dale K
North Dakota
Dale
I have a 1978 3/4 and I want to put a 4inch suspension lift on it. I have 16inch wheels on it now but would go bigger. I'm just wondering what would be the best wheel and tire combination for this size lift? How big can I go with out rubbing the fenders?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
16" wheel is good if you'd like to keep sidewall. 17s may have more tire options available, but it's not like there are a shortage of options in 35" tires for a 16. I think a 35 would fit a 3/4 with 4 inch lift well. metric would be 315/75r16 for a 34.5" OD
Depends in the brand of springs. With softer springs, even 33's can rub the fender on full stuff.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Also if you remove your front sway bar for a better ride and for better articulation the tire can "get stuffed" easily. Here is a pic of me playing around with a 3" lift and 285 tires (33"). A bigger tire wouldn't fit without rubbing or some trimming going on.
And I do have extended competition style bumpstops on the front.
Edit: front springs are Tuff Country HD springs...
Craig 85
Nashville, TN
454/TH-400/NP205
This truck had Tuff Country 4" soft ride springs. Granted I ran old school 16.5"x 9.75" wheels with 33's (32.8" tall), they would rub if I didn't trim the inner lips by the bottoms of the fenders. If you ran a 16x8" wheel with 4" of BS it may not rub with a a 305/70R16 (32.8" tall). I'm not sure about the 315's though.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Dale K
North Dakota
Dale
Thank you! I'm really enjoying this sight. Lots of good info.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I guess there really is a significant difference on what fits a 3/4 ton versus one ton due to the frame height and axles... I have 33s and no lift and a lot of room in the fender well. I think I can fit 35's as is but I'll probably do a 2ish inch lift if I go up in tire size.
smurfasaur
Central WA
Austin
Removing the front sway bar gives you a better ride?
Not really as much as you think. It has more to do with tire brand and sizing. Actual sizes are going to vary by brand. And then there's the metric stuff. 305/70/16 is a "33x12.5" for instance. But mine in that size measured an actual 33". But if you buy a "33" size if tire, it might measure as small as a 32". But a Dana 60 gains about an inch of front tire clearance all by itself.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
not sure what mine were new, but they measure 32.75" now ... Yokohama geolander at 285/75r16
ground to fender is a touch over 40" / centerline of hub to fender is a touch over 24.5" with about an 8" gap from top of tire to fender
A 285 is a narrow 33", so that is giving you some fender clearance as well as the narrow stock rims. If you had a 305 tire on a common 8 inch wide rim with 4 inch backspace, you would have much less room to work with. I'd bet a set of Q78 Swampers on your stock skinny rims would look awesome.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Swampers make anything look awsome.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I'd have to agree. but I got ATs to replace my old Yokohama's. maybe next time, lol
K10noob182
