- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
.60 over 350. running this combo for 21/2 years now. I didn't put the 160 in for the trans specifically. one of the best running small blocks i've ever had. Tell me why you think this is too cold even though i have no intention of changing it.
As with most things, engine operating temp is a compromise and running hotter or colder is really dependent on what you are doing with it. Colder is better if you are running WOT a lot and you want every little bit of extra top-end horsepower you could possibly get. It has been shown on a dyno that colder coolant temp will almost always translate to a few extra horsepower on the top end.
The warmer temp(210 operating temp on a 195 thermostat) is what OEM's usually spec for their engines. There are a few reasons why this is the standard and the big one relates to how close that temp is to the boiling point of water. By running the engine a few degrees over the boiling point of water it ensures that any moisture contamination in the oil is burned off to help with longevity and cleanliness of the engine internals and oil. It also aids in fuel mixture in the intake and combustion efficiency while also letting the oil run a little thinner to lower rotating losses.
In other words, cold is better for drag racing and hot is better for driving efficiency and longevity. YMMV
You wont start getting into danger areas for the engine until the 240-250 degree temp range and 50-50 coolant doesn't boil until 260+ in most cases with a functional pressurized system.
