- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
I'll give you some additive experience. I love telling this story, because it is the reason I stay away from almost ALL additives in engines etc.
I was a given a 99 Dodge Durango with the 5.2L 318 in it. Not a bad engine, plenty of power, but it kept losing oil pressure on the gauge, replaced the sender a few times, still nothing. Finally one day it just doesn't start, well after finally getting it started and limping it home I decided a new motor was in order. I bought a crate engine that needed a few parts off the old one. Suffice it to say this is what I saw:
After doing a little research I found out the P/O used Slick 50 religiously. Well thats apparently what it does, it gunks the living crap out of the motor. I was literally SCRAPING the oil off the bottom of the intake manifold with a paint scraper. NOT GOOD.
SO, when I see these fancy additives and fixers etc I get really, really leery. I won't trust it as far as I can throw it! If it was that good the manufacturers would be using it to begin with. Unless you need to clean old junk out, I would never add anything to my oil no matter what, unless its a junk engine anyway that you just need to keep running for a few days. Just my 2 cents (okay maybe 5).
Thats what everybody says, but he was religious about oil changes too, he took good care of the truck, he just used Slick 50...
What that reminds me of is, an OLD Penzoil motor. The parafene based motor oils would do that, especially if you stretched oil changes. Back then you really did need to change your oil every 3000 miles. That parafene is like candle wax.
