700R4 Noise - any thoughts?
tj43
Little Rock
TJ
V1500
My 88 suburban has made this noise as long as I have owned it. I only hear it in reverse or drive at parking speeds. Video of noise linked below.
The shifts you hear in the video are P>R>N>D>N>R>P. You can hear the noise when in reverse. I would describe it as somewhere between a rattle and a buzz.
Any ideas on what it might be? Car has always driven and shifted fine despite the noise.
Trans Noise Video
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The shifts you hear are P>R>N>D>N>R>P. You can hear the noise when in reverse. I would describe it as somewhere between a rattle and a buzz.
Trans Noise Video
Mine does it too, almost like a gurgle/growl? Low rpm as well, the lower the rpm the louder it is. Reverse is loudest and low speeds, no throttle/light throttle. I believe line pressure is highest in reverse.
To the best of my knowledge I believe it's a noisy pump. Does it way worse if the fluid level is even slightly overfull. 60,000+ miles still truckin. Just leave it alone!
Nborden88
