This is a coolant leak right?
tophat36
Bremerton, WA
Jessica
C2500
350-4 V8
I just want to verify this is the radiator leaking coolant. I drained coolant and ran a system cleaner. Drained again. Replaced both hoses, radiator cap, and thermostat (195F). Refilled with fresh coolant and ran until no more bubbles, about 30 min. Took a quick 5 min trip and popped the hood. I’m assuming this means I need to replace the radiator. If so, what are the best brand options? How do you tell if what you have is original?
Snoots
Roger
Jimmy Sierra
350 w/203
That's what it appears to be. Find a repudable radiator shop near you, drain and save your new fluid and pull the rad yourself. You'll save a ton of $$ on labor.
Personally, I despise aluminum radiators and prefer brass.
tophat36
Bremerton, WA
Jessica
C2500
350-4 V8
Okay thanks for confirming. Oh I would plan to swap it all myself…what is the radiator shop going to do, fix this one? Where do u find a good quality radiator that isn’t aluminum?
fast 99
Spokane, Washington
Other than an originality standpoint why do you dislike aluminum rads? From what I have seen they transfer heat much better.
There used to be around 10 radiator shops in this area. Now were down to 1. Getting radiators fixed and sourcing cores isn't cheap or fast.
OP, appears it may be leaking at the header and will need a core. Hopefully I am wrong and all it needs is resolder of the tanks. I was able to recore a 70 Mustang radiator a few years ago. The shop wouldn't guarantee it because of all the small tank cracks from age. I was also unable to find a copper brass rad for an 85 SB 2 years ago.
Rusty Nail
Rusty
350sbc
Meh.
I loathe the fact we must have this discussion. Please don't get me wrong - I think the factory did it right but this is 2024 and things change??
In my experience, there came a time when I made a conscious decision to become more willing to go with the flow.
That applies heavily to Classic trucks :imo:
Sure you MAY BE ABLE TO get your old ass radiator rebuilt but at what cost? How long do you want or have go spend doing it?
Ya like playin mechanic a bunch do ya?
Look. There may come a time when you decide to choose your fights more wisely. It's very simple, quick, and easy to run to the store and bring home another unit then install it before supper and it'll probably have a warranty.
Probably in stock.
I had such trouble getting my oe part repaired I got a plastic one and didn't look back. Hope this helps. Sure, I could have forced it.
Snoots
Roger
Jimmy Sierra
350 w/203
Corrosion. No offense to @fast 99. I've seen more on aluminum than brass. Types of anti-freeze, no anti-freeze? I don't know.
A radiator shop will pressure test it to find the leak, tell you whether or not it is repairable; if so they can boil it, rod it out, fix the leak, pressure test it again and paint it.
fast 99
Spokane, Washington
Interesting, do you suppose part of that could be from numerous electrons passing to and from nearly every part of later vehicles that have OEM installed aluminum rads? Just a thought.
Haven't seen to many rotted out cores. More often tanks either denature from excessive heat
[low coolant] or tank seals themselves leak.
Had one case where a 93 GM truck was rotting out heater cores [aluminum] in a month. After 3 of them [flushes each time] added a ground. Ran wire through the same opening as the hose, grounded to the firewall. Never had another problem with it.
tophat36
Bremerton, WA
Jessica
C2500
350-4 V8
And what does something like this cost….also how do I tell if u even have an original radiator? How do u measure what you have installed. Mine is the 3-row version inside
Snoots
Roger
Jimmy Sierra
350 w/203
That is a question best answered by the shop. All I can suggest is that you not lose the rubber mounts and if possible, replace them. I don't think the shop can help you there. I suggest you check out LMC.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
If you can find the leak yourself there's some radiator puddy I got from Walmart or parts house that works really well. I put it on the 82 and it has held up well. I was gonna buy a new one but tried that first and it's help up ever since. Just another option for you. I'll take a picture of it when I get home if you want me too.
Aluminum radiators will destroy themselves if they become a battery, yes they do this. Put a positive lead from a multimeter into the radiator and ground the negative lead to battery. Check for voltage,engine running,loads on, headlights,heater blower etc. Shouldn't be any, I am not sure if the antifreeze becomes acidic or not but stands to reason it would. Anyway it's something to check. They also like to have a sacrificial rod in them,just like a water heater,so the sacrificial rod gets eaten instead of the radiator. Look up water heater sacrificial rod and read about it,it's usually the difference in a longer warrantied water heater,2 sacrificial rods instead of one. Thanks for reminding me I should probably change mine as maintenance.
malibuman402
nc
Larry
C10 Silverado
BB 402+.060 = 413.8CI
try champion radiators, worked for me. and maybe a 180 thermostat.
72velle
Kevin
OK, if you have an old parts store in town just drop by and see what they have in stock. Costs you nothing but your time. The radiator in my 72 Chevelle started to give me problems. I called the local parts store that had been around forever and they had a brand new, heavy duty radiator in stock for $120. Pulled the old one and replace it by myself while my leg was in a cast. Best $120 i spent on that car.
Rusty Nail
Rusty
350sbc
Look I'm not talkin chit (much) but you could have fixed it that day - A WEEK AGO.
Ye olde radiator repair shoppe and them "good olde days" are long gone even though the truck remains.
You're the only guy that is gonna make it easy on you..tryin to help. :shrug:
Hard
