TH400 rear mount spacers
Dave M
Banned
Australia
Dave
Can someone tell me the thickness of the two spacers, shown he diagram. Mine doesn't have these.
Weird. I don't remember seeing those before. I wonder if my '78 has them.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have removed several from core transmissions over the years. I’ll try to remember to grab a couple tomorrow for measurements
I hope I can explain this so it makes sense, the actual measurement isn't really that important, what is important is that the tailshaft of the transmission and rearend pinion are on the same plane.So if your tail shaft is level with the ground your pinion needs to be level to the ground.If the pinion is canted up 2 degrees the tailshaft needs to be canted down 2 degrees. You can get an angle finder app for your phone check the angle on the rear yoke and raise the end of the transmission match it.
