Th400 hanging between 2nd and 3rd
Kevin83chevy
North Carolina
Kevin
I have an 83 with a semi modified 350 with a thm400. I drained the fluid and changed filter. Found metal shavings and one small chunk of what looked like a gear in pan. I can drive truck for about 10 miles and when it changes from 2nd to 3rd, sometimes it will hang like it's slipping. If I let off throttle, it'll fall in 3rd. I also do not have a decent switch connected nor a decent cable. Any suggestions? I'm pretty sure I'm looking for a rebulid, but wanted opinions. Thanks
74 Shortbed
Welcome to the site!
You have broken parts in there driving it will only make it worse, time to pull it and rebuild it before you destroy it..
Kevin83chevy
North Carolina
Kevin
Ah, not what I wanted to hear lol. Thanks, where would be a good place to get a rebuild kit with Kevlar clutches and bands.
74 Shortbed
Well, there's a lot of good sources out there but I've never dealt with them since I get everything I need through a friend of mine, but I'm sure others on here know of good places to get parts, but it sounds like you're gonna need some hard parts as well as a kit...
robracing85
