th350 rebuild
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
How hard is it for someone who hates/has never done much transmission work to rebuild and beef up my th350? I found a B&M kit for $400 on summit which is supposed to let it handle a little more abuse too. I might drop the trans and do it myself who has done it?
74 Shortbed
Done a $hit load of them they are easy, don't know if they still do but B&M full kits used to come with a step by step manual with pics from tear down to to full assembly real easy to understand..
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
74 Shortbed
That's the one, and guess they still include the manual too according to summit..
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
Cool, will probably try it then. If I fail, my neighbor has a transmission shop so I'll go to him with it ha!
74 Shortbed
Just take your time and pay attention to detail, and follow the instructions and you'll do just fine...
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
It's very doable. There is lots of online writeups. I bought an older HP Book on rebuilding TH350's and it was helpful, but not needed with the online stuff that's available.
I rebuilt mine in June, with a 700R4 low sprag, fancy-schmancy case saver, hardened intermediate sprag, machined the direct clutch down to fit a fifth clutch and steel, and installed a Transgo shift kit. The B&M shift kit should not be used as directed - it's hard on parts.
You need a couple specialty parts, or creativity to disassemble. Check the online builds and you will see what you are getting into.
If you are very organized, and very meticulous, you will do fine.
thinchey
