TH350 question
Corey
Ft. Bragg, N.C.
Corey
350/TH350/NP205/4.11gears
I'm in need of a new Trans because reverse is out in mine and I can find plenty for 100-200 dollars but no 4X4 applications near by can I swap the tails of them so it will work with my NP205? If so then I'm in business! My only worry is if I buy it and attempt to swap the tail sections and the output shaft will be to long and I've waisted time and money.
thanks for the help
Corey
Ft. Bragg, N.C.
Corey
the one I want would be coming out of a Malibu for a price of next to nothing
The tail shaft would be way too long. You have to get one from a 70's 4x4, it doesn't matter if it had a 203 or 205 behind it.
BigAl285
Wisconsin
Allan
383 S.B.C
You would have change out the tail shafts. To do so you have to pull the who transmission apart. At that point might as well just rebuild the one you have or find a 4x4 trans. I'd rebuild it.
Corey
Ft. Bragg, N.C.
Corey
thanks guys yeah that's what I was thinking. I think I found one for 200 about 4 hours away that's coming out of a wrecked truck but was rebuilt and has a B&M shift kit in it so hopefully that works out and I get the upgrade too.
Swims350
Logan WV
none
if it's the b&m shift kit I had you'll like it very much. Not sure on a 4x4 app. tho. I ran it in a car and it'd bark em nice switching gears.
swagger
old house in WV
Steve
350/SM-465/NP-205
I would get the car trany and put the good parts in the 4X4 case. Its not that hard, There are books/vidos on the rebuilding process. I believe the book tells you how and where to drill the plate for firmer shifts, and what balls to leave out.
Its not rocket science
Steve
davbell22602
Bunker Hill, WV
I Dont
Have
One
Steve
Do you have a link to a book the does? Would the HPbook turbomatic 350 have in it?
swagger
old house in WV
Steve
350/SM-465/NP-205
I have one somewhere. I'll look for it. I hope its not packed up yet. lol
summit sells the books and vids
Steve
Corey
Ft. Bragg, N.C.
Corey
did some trading and got a TH350 that had been rebuilt about 6 months ago. this
[/IMG]
for that
[/IMG]
FenderBanger
