TBI Spark Plugs
custodian
Catawba
William
5.3 LS, 350
I'm putting a set of TBI heads on my 75 350 that I'm building. they have the 1.94/1,50 valves and 65cc chambers, casting #14102193 and used on a 87 up 350.
Now my question: What spark plugs are used in the TBI heads?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
my 1987 TBI uses ACDelco CR43TS
Are you planning on running TBI though? Just curious why you would choose those heads if you're still running a carb. They weren't exactly great heads in any aspect
custodian
Catawba
William
5.3 LS, 350
Running a carb. Replacing a 6.2 diesel with my 75 350 with TBI heads. This is a standard build 350 for my youngest granddaughter who is 15 at the time.
Catbox
Peter
C20 Silverado Camper Special
I saw one of the magazines call these heads the worst flowing heads GM has mass produced.
My Suburban wears a set and we have terrible mileage and the engine is totally done at 4,000rpm.
Perfect for a kids truck.
Don’t the TBI heads have a different intake bolt pattern too? Middle two bolts on each side are at a different angle than the carb heads, right?
custodian
Catawba
William
5.3 LS, 350
Yes, different intake bolt pattern in the middle. I have the intake. The motor I'm building came with these heads and the intake, just using what I have. Not building a power house.
RecklessWOT
New Hampshire
Kevin
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
NGK V-Power Nickel 2771 is what i recommend they are much better quality than the chinese made delco plugs.
Jay Don
