tbi issues
lucifer6669
las vegas
jaime
jimmy
350 from a 94 suburban
im new here and i just recently bought a 86 gmc jimmy with a 350 motor from a 94 suburban. My current issues is the throttle getting stuck open sometimes when i hit the pedal. and when it gets stuck i have to pull up on the pedal for it to go back to normal. what can be the cause? nothing out of the ordinary that i see. thanks for the help
85squaredC10
Wisconsin
Jason
Sounds like the throttle return spring in the throttle body is weak/broken. Replace that or add a throttle return spring like in a carburetor setup and you should be good.
Sent from my SM-G965U1 using Tapatalk
Todd Lemon
