t case swap info needed.
eastcoastmat
mathew
k10 Scottsdale
Hey guys! Bought. This 76 k10 over 2 years ago and other than a tune up,carb rebuild,and a few u joints ive just been driving it daily. I recently bought a 78 parts truck that has a 4"lift new hood,fenders,doors,nice seat and a 14 bolt ff. My 203 tc is making a poping sound under load. 2wd is fine. I'm assuming chain is stretched. Parts truck has a 208 tc and same 350 tranny. Can I just swap them out. Or are the splines different? Thank for any input.
firebane
Calgary, AB
Curtis
NP203 is fulltime 4wd and only has a 2hi when a part time kit is install.ed
eastcoastmat
mathew
k10 Scottsdale
Correct! It has a mile marker kit installed.
BowTieJockey
Tallahassee fl.
Trey
It should swap in besides driveshafts but if you use the parts truck shaft provided that it's the same body such as long bed and what not. You will Ned the shifter form the diner too.
eastcoastmat
mathew
k10 Scottsdale
Yes both longbeds. Parts truck only came with rear dshaft. Do I need a front also. Or will mine work?
BowTieJockey
Tallahassee fl.
Trey
I'm not sure on that one. That's a @HotRodPC question. Ibwouldnt think that they would be different. Oh wait the 208 has a flange for the front shaft and a 203 is a yolk style if I'm not mistaken.
eastcoastmat
mathew
k10 Scottsdale
No its a flange style. Thanks for the info! Much appreciated. Time to get my 4wd back!
You will have to mod the front shaft. You will also have to use the Th350 with the NP208 due to output shaft length difference. The NP203 output shaft is very short, like a stub, so the shaft on the NP203 unit won't reach all the way through the adapter into the NP208 splines.
Now that I think about it, that shaft might work, because of a longer slip yoke. The older shaft doesn't have the double cardan joint right? So it has longer slip yoke IIRC. You'd have to ask someone to measure and get pics of the flanges for you that has an NP203. And I get confused with NP205's and NP203's too. But I'm certain on the output length on the Th350 trans.
eastcoastmat
mathew
k10 Scottsdale
Thanks guys. I'm gonna tear it apart and go from there. I have both trucks so I should be good. BTW. Both have same tranny.
Yes, the trans may be the same, but the one with the 208 bolted to it has a longer output shaft.
boarder421
