symtoms of moduale failue on 1977 c10 with a 350 tng
allan Johnson
monnesota
Allan
c15
symtoms of modual fail on 1977 c15 with 350 eng
What??
Are you asking what the symptoms are of an ignition module failing? Generally, the engine just dies and will not start. No spark at all. Sometimes you might see erratic spark or timing jumping around due to a failed module.
allan Johnson
monnesota
Allan
c15
thanks,mine does that,after a short it starts,i though it mighr be vapor-locking as we had alot of 90 degree days here,but its only 77degres today,i noticed higer heat soak latly as well,i bought a modual,ive heard froends that this is fairly common on 350 chevs,the modual gets hot and the coil wont fire,thanks 4 the response!
When you change the module, make sure you use all of the heat transfer paste between the metal back of the module and the body of the distributor or it will overheat. Also make sure the engine and wiring has all ground wires clean and connected. Poor ground connection will cause more heat in the module and cause it to fail faster.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Sometimes they fail completely, sometimes they fail only when they get hot.
holleytool
