Switching to dumbo mirrors
Chris64
San Diego
I found a couple templates for their location. It seems like in pictures most people line it up in the middle with the wing-window support bar. The factory location is a few inches forward of that.
I didn't get the bracket that goes inside the door (yet). If I do get it, I think that will dictate where they go.
My questions:
1) I'm not a huge fan of the plastic inserts. What do you guys think about using (maybe stainless) threaded rivets instead?
2) Considering the above, is the bracket necessary?
Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
No marks or dimples on the inside of the door where the inner plate mounts? I’ve only ever seen them on
ali_c20
Austria
Alexander
C20, K5
Threaded rivets are ok. Don't use stainless as the sheet metal that is contact with them will rust very quick ( galvanic corrosion). Use standard ones with zinc plating. I did dumbo ears on a friends K5 with threaded rivets. We made a reinforcement plate from sheet metal of an old door and glued it with 2k epoxy to the inside. Then we installed the threaded rivets and the mirror. We used 5/16 bolts.
Daron58
Ponchatoula La.
Daron
250 I6
I used rivet nuts, they make aluminum ones with the steel thread and the brackets that go in the doors can pivot left or right I just did mine, let me know if you need a picture with the measurements I’ll send it to you
jacjr1479
California
Jessie
My questions:
Chris64, do you have a copy of the template you can share?
Chris64
San Diego
I actually do, but it didn't really line up to anything for me. I ended up just eyeballing it. I think I centered the top with the back of the wing-window.
jacjr1479
California
Jessie
Thanks for sharing. I'll have to print and see how I can line it up, might have to do the same thing and eyeball it. Thanks again!
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Do you still have the measurements. I'm in the process of changing over to Dumbo's on my build! diregard didn't read the whole thread.
hoagster
California
K10, 1500
5.3l
I thought your truck was painted already?
It is but it had those huge tow mirrors and I welded all the holes for those monsters since they were jacked up/ I know I should have drilled everything prior to paint but I'll have to live with it!!
Ken B
indiana
ken
I did not have any reinforcing , backing way back when I went to dumbos. The metal on the door actually split due to closing the door over the years and the weight of the mirrors.
Camar068
10 yrs Air Force
You can also use Well Nuts. They are used to hold roof racks on and will be fine for mirrors.
wow....never thought about well nuts for my visor. Have to change them as they dry rot n such tho.
[edit] lol more thought....hard to get to for my application.
Thx Dude
Rudy Mienert
St. Petersburg, Florida
Rudy
Blazer
it seems Im joining in the middle of this conversation, but I am switching from my "West Coast" to the dumbos, and am searching for measurements to drill the holes before paint. The critical one seems to be the lowest, as that attaches to the reinforcing bracket inside the door. The template here doesn't have measurements, ans refers to an "existing mirror hole, which may or not be where my current mirror holes are. Any more detailed illustrations/measurements??
hoagster
California
K10, 1500
5.3l
I just put mine on and the critical placement is the upper two. The skin in doubled at the top. My doors are not drilled on the inside for the lower reinforcement bracket 73 year model. Two members took pictures of the measurements @TotalyHucked is one. I think if you do a search with his tag you'll find it. Here is how I did mine and they are solid.
Take your time with the placement, mine aren't perfect but I'm happy with it. Used a smittybuilt nut cert tool.
https://www.smittybilt.com/shop/tools-storage-garage/nutsert-tool-kit-2834/
that_orange_c10
