PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- Suburban k10, bonanza k10, c30 C&C, c10, gmc 1/2ton
- 350, 350, 350, 350, 350
Ok so I have a 1984 suburban with a 400 that I believe was swapped before I got it, to the best of my knowledge suburbans didnt have the 400 as an engine option before 85. But it has a 700r4 behind it. The problem is that it has a vibration only at really low rpms when it kicks into overdrive, I can't tell if it's the engine or if it's a u joint (or some other problem)The hubs Werent locked in and was in two wheel drive. It doesn't seem to make sense since its an extremely noticeable vibration that ONLY happens in overdrive at low rpm and that's the only time it happens any ideas?
